MAX7 - NURBS modelling... simple question - help!
spiderdad
i have been modelling with nurbs in max...
when i try to modify a surface/curve a small toolbar turns up, it simplifies a lot of the commands i normally need to trawl through and painfully figure out...
but silly me.... has closed this toolbar... and now i can't find a way to get it back... :-(
can anyone please help...?
Dec 4, 04 1:30 pm
trace™
It should pop up when you got the Modify panel. If it doesn't, just make a new nurbs spline/surface and go to the Modify panel. It should pop up when you click on the tab.
This is Max 6, though, haven't gone to Max 7 yet.
Dec 4, 04 2:25 pm  ·
spiderdad
thanks trace,
that hadn't work...
but i found a button under the general sub-menu (unders NURBS modify)... that makes it the toolbar pop up.
fyi: you can download a trial version of 7, from discreet.com
Dec 4, 04 2:31 pm  ·
trace™
yeah, I don't use nurbs often, only for playing around, really.
I'll wait a while to upgrade to 7. Right now I need to keep things compatible, and all my computers have 5 or 6. I'll try to do the big upgrade at once, but the $$ seem so absurd (why can't they follow Softimage!!??).
Dec 4, 04 8:07 pm  ·
doberman
regarding nurbs modelling in max. i was once told that there is now a way to integrate Rhino into the MAX interface for improved NURBS modelling, is that true?
Dec 6, 04 8:28 am  ·
French
I'm not sure what your question is, but if it is about importing rhino model into max, it is really easy and efficient. That's the only way I ve found to use nurbs in max anyway (the integrated tools just suck)
Dec 6, 04 8:51 am  ·
