I recently got a new plotter and am looking to plot using my old ctb. files. I can't see them in the plotting window. They are only giving me .stb (named plot files). How do i import my ctb's?
depends on what version you use. but if its 2004 or 05 your plot styles folder is under your document and settings folder - under autodesk. the other issue could be if you start a drawing using .stb instead of .ctb you will only get a menu of .stb check autodesk to see how to return that setting...
Dec 2, 04 1:05 pm ·
.stb vs ctb.
