How to extract sections, plans, and make2Ds from a 3ds Max model?
mark lower
i am a rhino user that just figured how to model using polys... but how do i get drawings from the model?
in rhino i can get vector drawings (plans, sections, make2ds) and import them to illustrator to adjust the line weights...
can i do this in Max as well... or do Max users use another workflow?
Feb 15, 11 12:55 am
TheRevitKid
Use Revit!
Just import it and set up some views...
-Jeff
www.TheRevitKid.com
Feb 15, 11 8:43 am  ·
There is a 'slice' modifier that will cut geometry. I don't know if that will get you a vector drawing, but you can probably do something with a bitmap and photoshop.
Feb 15, 11 9:24 am  ·
olaf design ninja
goto Command Panel/Create/Shapes/Section
the Section like slice will cut a yellow line through the object, once you have it located with Section selected goto Modify Tab and click on "Create Shape"
Feb 15, 11 10:29 am  ·
olaf design ninja
olaf design ninja
Feb 15, 11 10:30 am  ·
