Mechanical Room Rating Requirement
aadesign
Good afternoon all,
I've been studying since several code sections trying to find out whether a mechanical room needs to be rated or not. Here the facts:
its a 2 story F-4 in NYC (or A-2 as per 2008) fully sprinklered space. prep in cellar, eating an drinking on first floor . Construction Class is IIB.
There is a 30 tonne unit on cellar level, feeding both floors. No combustion.
As far as I know all penetrating ducts have dampers.
My question is if i need a rating on the mechanical room demising walls and door.
It would be great to get some feedback or if someone could direct me to a code section that will answer my question.
Thank you very much!
Jun 9, 14 2:18 pm
gruen
Depends on size of the unit and size of the room. Read the building code, mechanical code and appropriate NFPA codes.
Jun 9, 14 5:24 pm  ·
Palowe
Have you checked BC 508? If you say all penetrations have dampers that implies you have a fire rated wall, whether is 1hr or 2hr.
Jun 10, 14 9:59 am  ·
gruen
There might be a floor rating w/o any wall rating reqmt. OP needs to give us more info about the equipment and room size
Jun 10, 14 10:57 am  ·
gruen
Check fire code too
Jun 10, 14 11:09 am  ·
