PDF to dwg - recommended convertors/software?
vvvijay
Hello all,
I am looking for a reasonably accurate + reliable pdf to dwg convertor... Anyone have any experience, recommendations...? I have tried using a couple though they have not been accurate (various scaling issues).
Would appreciate any insights.
Nov 9, 09 11:45 am
archiTEKE
next to impossible - if the pdf was created through a vector program u can use illustrator and "livetrace" the file. but even still its not the most accurate.
Ive also herd of rastorcad....i dunno much about it though
Nov 10, 09 3:55 pm
LML
rhino imports/exports these file types. not sure about the scale issue though...
as far as live trace in illustrator, there's no need if it's already a vector based pdf--just open it up, ungroup as needed, and edit. raster based would be another issue
Nov 10, 09 4:26 pm
grid
open it in illustrator then export as dwg.
Nov 10, 09 5:42 pm
JudyFennelly
You can try this converter http://www.autodwg.com/pdf-to-dwg-converter/
as there is an option to set the scale of the conversion.
Jan 10, 10 9:17 pm
drop it in rhino and export as a .dwg file. keeps the lines clean and whatnot.
Jan 11, 10 12:20 am
Please wait... loading
