rhino to 3ds max? not every side renders
eightinchscale
Hi,
I'm exporting a rhino model as a dwg (also I've tried it as a dwf), surfaces and curves to polymesh. Once imported into studio max though, not all the surfaces render. For geometry as simple as a box or a wall, only two or three sides will render. By rotating the box or the wall, the other surfaces will appear while the previously rendered ones disappear.
Has anyone else encountered this problem? What's a way to fix this without having to rebuild any part of the rhino model? I'm using rhino 4 and studio max 8. Thank you for the help.
Nov 5, 07 8:43 pm
Philarch
I haven't had a good track record on Archinect on giving good advice recently, but I had a problem similar to yours that I fixed by turning on "Render Hidden Geometry" and/or "Force 2-Sided" under Common Parameters - Options. Hope this helps.
Nov 5, 07 8:58 pm  ·
psycho-mullet
Sounds like good advice to me. Force 2 sided should do it. You can also select 2-sided at the material level under "Basic Parameters".
Basically the surfaces have an up and a down side (called "normal")and by defualt max doesnt render the down side for example the inside of a cube. It's like a way of saving a bit of memory and rendering time, primarily I believe its for videogames where resources are limited and speed is important.
The problem when importing is the way other modeling programs build the model sometimes the downside is up. So in an extreme case you need to edit those faces at the sub object level and flip the normal. But in this case force 2 sided should be suffecient.
Nov 5, 07 9:48 pm  ·
Urbanist
yep.. inverted normals hapens at lot when you move from Rhino nurbs to 3ds max subd modailities. force 2 sided is a quick fix, as psycho-mullet and Philarch suggest. It didn't work once for me on a complex landscape model though, and I needed to edit faces for an entire complex landscape model at sub obj... not fun. If force 2 sided doesn't work, let us know.. there's a few other slightly more involved fixes that may still be quicker than selected and editing each face.
Nov 5, 07 11:37 pm  ·
French
It shouldn't happen if your orbject was already a closed surface, ie a solid in rhino, before you transform it into a mesh.
Nov 6, 07 9:24 am  ·
ichweiB
select the object
go to properties
click either the of the red polygon selection buttons
scroll down to flip faces or flip normals....
Nov 6, 07 11:39 am  ·
