Type in AutoCAD
matt22
I'm trying to make stencils on AutoCAD and then laser cut the pieces out. I used the type tool and the Lasercamm did not recognize the type as part of the drawing. I'm wondering if there is a way I can turn the type into an regular lines in the autocad file.
Apr 7, 16 4:02 pm
Laser cutters dont like certain fonts (true types & raster if I recall correctly).
Apr 7, 16 4:10 pm  ·
cadomestique
Explode the font to lines and arcs. Problem solved. //
There's a free LISP rutine for that.
Apr 7, 16 4:19 pm  ·
or run it through illustrator to convert to outline first
Apr 7, 16 4:39 pm  ·
matt22
how exactly do you use illustrator to do it?
Apr 7, 16 4:51 pm  ·
Stasis
matt22,
Create  a text in illustrator, then go to 'type' menu on top to find 'Create Outlines' tool.
you can also use a keyboard short cut 'Shift+Control+O'
Apr 7, 16 5:58 pm  ·
matt22
Thanks for the help
Apr 7, 16 6:03 pm  ·
cadomestique
@ proto
No need for additional tools, when exported to autocad format all text is already exploded to simple lines.
Apr 7, 16 6:10 pm  ·
