Maximum quality going from PS/ID to PDF?
hankd
When I am at 100% zoom on InDesign, everything looks crystal clear and sharp, but after sending it to a PDF file on maximum settings, everything looks blurry at 100% zoom or even 75% on Adobe Reader. Any way around this?
Nov 30, 09 10:42 pm
rehiggins
if you're creating a "print quality" PDF, it's going to look a little funky onscreen but it should print OK. If your goal is to present via a projector/monitor, create a lower quality PDF
Nov 30, 09 11:18 pm  ·
LML
what's the content?
Nov 30, 09 11:43 pm  ·
hankd
rehiggins, never knew that. I am wanting it to be printed, and put it on max quality settings (so the PDF file is around 60MB). However, quality still seems somewhat reduced nonetheless. I'm hoping I can just send them the original individual pages to print out instead of the entire PDF file since PDFs always seem to suffer reduced quality. LML, the content is all images.
Dec 1, 09 10:31 am  ·
LML
in indesign, the export dialog has settings for both resolution (i.e. 300 dpi) and for compression type/quality (i.e. jpeg, "maximum"). You might double check that you've got both of these where you want them...that is a big file, but that also varies with how many images you're including, etc
Dec 1, 09 11:01 am  ·
trace™
you can fairly easily control the output and compression for each kind of document.
I've never had a problem with this, though.
What is the resolution of the files you are using? Are they compressed at all prior to ID?
Dec 1, 09 12:13 pm  ·
rehiggins
there's also a way to create a PDF that has proxy "blocks" that automatically swap out for the high-res images at print time, but this leads to coordination issues with the print shop.
Dec 1, 09 8:37 pm  ·
hankd
i see
Dec 5, 09 3:48 am  ·
