InDesign Tiling
jackhogan
I will be laying out a 3364 x 1188mm presentation in InDesign next week that will be printed on 32 A3+ sheets, and cropped down to A3 (full bleed) to join seamlessly, with no overlap. Is it possible to set up the document to appear as the matrix of sheets, a spread of more than two pages - eight A3 landscape across by four down to be precise. This would be ideal, as I will want to test print single pages without having to move the entire presentation around to get the right bit onto the page.
Failing that, when printing/exporting, how can I get InDesign to tile the layout onto A3+ sheets, with A3 crop marks? In print dialog, if I select the page as A3+, it assumes that I wish to use the full printable area, therefore tiling unevenly onto fewer pages..
Alternatively, can the print box itself be moved (like in VectorWorks), in which case I could just snap to an A3 grid and print individual sheets?
Thanks in advance.
Apr 12, 09 4:26 am
LucasGray
I would export to a .pdf and do it in acrobat - you can tile and add hash marks and all that jazz pretty easily.
I'm sure there is a way in InDesign.
But why 32 A3 sheets? why not just take it to a plotter? I mean it will be more expensive to print but it will look better and save lots of time! Printing and trimming 32 sheets will be a pain and the trimming process is never perfect so they probably won't line up exactly right.
Apr 12, 09 7:13 am  ·
Not sure if this is the ideal method, but have you tried manual tiling? Here's a how-to link. Manual Tiling
Another way would be to export the Indesign file to Illustrator and you can move the print view in the print dialog.
Apr 12, 09 12:35 pm  ·
jackhogan
Thanks Nicholas-- Yes, I have been using the manual tiling method, moving the zero point on a grid of my own A3 crop marks, printing onto A3+. It seems that this is the easiest way, as all the crop marks line up, facilitating tear-free trimming.
Lucas-- While I appreciate your $0.02, I have many good reasons for printing 32 sheets. 1. My A3+ inkjet is 8 ink, while the plotters are CMYK. This means that I get much better colours, greys in particular - for example, a 10% K will be printed using the light grey and light light grey cartridges instead of a 10% mist of black. In my experience, this looks better than a seamless plot and always lines up perfectly. 2. All 32 sheets will be cut with four passes of a laser-guide guillotine, which is rather accurate. 3. Single sheets can be updated/test-printed easily, at any time of the day/night, without waiting for the use of a large-format printer.
Apr 12, 09 12:55 pm  ·
jackhogan
And gaps can also be quite nice..
http://www.experimentaljetset.nl/archive/naim-state-alpha.html
Apr 12, 09 3:43 pm  ·
LucasGray
That's a ice presentation Jack. Thanks for the link.
Apr 12, 09 3:52 pm  ·
rehiggins
Jack--
just curious: which printer are you using?
Apr 12, 09 3:55 pm  ·
rehiggins
Jack--
jackhogan
Epson 2400 - I would highly recommend it. The K3 ink is expensive but really worth it, especially for matte prints. Best greyscale quality that I have seen.
Apr 12, 09 3:58 pm  ·
jackhogan
Stylus Photo R2400, to be precise!
Apr 12, 09 4:07 pm  ·
rehiggins
$14 or so per cartridge isn't bad--I have a Stylus Color 3000 and filling that each time is like buying a new low end printer or two…I just realized this fact as I typed it btw; lovely
anybody know anyone that wants an Epson Stylus 3000?? (very low mileage)
Apr 13, 09 6:04 pm  ·
