1.
Drag the RHP into the Rhino interface.
2.
Go to the Render pulldown > Current Renderer > Flamingonxt
3.
From the Flamingo nXt pulldown select Control Panel.
In the WIP 2 (3-16-2009) we have added:
Moved Depth of Field controls from the DocumentProperties/Flamingo nXt page to the Flamingo control panel, Render tab and hooked up controls.
Added Ground Plane options to Control Panel Rendering tab
Added true model instancing.
o
If a Rhino block is inserted 3 or more times then instancing is activated.
o
Once instanced, any number of copies can be inserted with a very small additional memory usage. For models with a lot of repitiion in the model this can save a huge amount of memory.
Modified Flamingo to use Rhino runtime render mesh and only create meshes when absolutely necessary. This may improve translation speed at the start of the rendering process.
Added ability to cancel during meshing procedure.
Flamingo Document Properties includes options for:
o
Use legacy 2.x or 1.x Flamingo materials when rendering (this can slow the rendering down quite a bit)
o
Minimum block reference to turn into tool kit instance
Improved crash protection during meshing
Optimized legacy material support to use imported material definition as long as name has not been changed
Restored missing controls from Advenced Tab in the background HDR, Bitmap and color dialogs
Replace Rhino Object Properties Light page with Flamingo nXt version when Flamingo nXt is the current render plug-in
Added right click properties option to the Flamingo Control Panel Light tab light browser
Changing manual sun values now works
Flamingo NXT Mapping controls Updated
Added initial plant support. You can import plant files generated with the “C:\Program Files\Flamingo nXt WIP\TreeEditor.exe” or “C:\Program Files\Flamingo nXt WIP\TreeEditor64.exe” program
Control Panel, Lighting & Background tab now includes a color bleed option
HDRI properties page now includes a saturation option. This controls the color satuation of the light coming from HDRI files. The default value has been set to .5. 0 will lead to neutral white light coming from the HRDI. A value of 1 will lead to light that is fully colored by the sample point on the HDRI.
Various bug and crash fixes.
Inside the advanced tab, refractions option, Custom, HDRI. In the HDRI selection box the controls are all messed up.
Sun Direction now will update when angle changes.
Metalic color updates properly
Exposure adjustments controls now spin smaller increments.
Updated installer to un-install properly.
Flamingo/Accurender nXt
This is an early version of nXt for Rhino.
Once you download it you need to:
1.
2.
3.
o
o
o
o
like how it solves the shadows rather than the light
