the background in max doesn't have any variables that can be animated.
you need to apply the bitmap you've used as your background to a plane aligned with your desired view, but be aware, your render settings will apply to the plane and bitmap and may need adjusted so as to not wash the image out.
3ds max 2009
I cant seem to animate my background texture using autokey mode in max 2009. any help?
how funny is that? in max 2008 you could animate it!!!
