Alright! I'll get straight to the questions! This is with regard to the normal Desktop Vertical Computer Chassis. >Have you ever faced problems with your computer cabinet? >What formfactor motherboard are you using? >What are the problems you've faced? - with regard to the layout/serviceability & maintenence of the system? >Do you have trouble with the airflow inside the cabinet? Does your processor overheat? >Do you think there could be a better way of configuring the internal layout? > How many optical drives do you normally have? > How many hard drives do you generally have? >Do you think the smps (Power Supply Unit) is too bulky? Could something be done about that? Would really appreciate your resposes. Thanks
Regular Computer Cabinet problems??
Thanks
