question, if i have a data room that has floor to slab cement brick walls, what is the fire rating on it. Just have to ensure that it has a fire rated door to make this area fire rated
Handsumca$hmoneyYo, appreciate its homology at other walls, ligt the gray be drawn.These face to the wall wall to get to lead iinto a to load in to depend wharf district.
_____________________
May 25, 11 9:38 pm ·
Fire rated wall
Be sure to review the UL design numbers at the bottom left.
http://www.westbrookblock.com/products/blocks/ul/index.htm
You will need to address the conditions where the CMU partition/s terminate against other building components per the UL design you choose.
What color is the wall? Because if it is red then it is probably fire-rated, yo!
Handsumca$hmoneyYo, thanks it is painted the same as the other walls, a ligt grey. These wall lead iinto a loading dock area.
leading walls....ya that is the ticket...! Kahn has company! " I want to be a leading wall."
you have to have joint ratings, and penetration ratings to have that room rated..not only door and walls
