How to upload portfolio for grad school applications?
Noypi
For online applications, how are you guys uploading your portfolios? Right now, I'm just printing them into pdfs from InDesign. However, this just creates continuous singles pages. How do I create a cover page followed by spreads (like in issuu)?
Dec 17, 12 2:03 am
Jono Lee
apparently, they have programs that allow portfolios to be viewed like spreads. at least yale does it that way
Dec 17, 12 2:08 am  ·
blyang
in indesign, go to document presets under file, and it should have a setting to allow you to view the document as spreads. then export that into pdf and it should be in spreads.
Dec 17, 12 4:11 am  ·
Kamu Kakizaki
another thing to note (for myself as well) is to try to have everything in the indesign including linked files in either RGB or CMYK. if you have both in one file the blacks and transparencies starts to get inconsistant.
Dec 18, 12 3:46 am  ·
@Jonathan Lee
Do you know how portfolios on Yale upload site should look after they are "post-processed"? The upload instructions mentions being able to reorder and drag thumbnails, but I waited overnight for the post-processing to finish and there's still only one thumbnail showing...
Dec 23, 12 9:31 am  ·
Jono Lee
If a small graphic thumbnail appears, then you're good. But to be certain of how it should appear, I would call them to be sure
Dec 23, 12 3:37 pm  ·
Great, I do have the small thumbnail. I'll try sending them an email since it's the holidays? Thank you!
Dec 23, 12 3:44 pm  ·
our offices will be closed until the 2nd.... so you wont get a response until then fyi
Dec 24, 12 4:33 pm  ·
to be honest though... the fact that you've worked for pelli and sanders... you are already in yale. dont worry.
Dec 24, 12 4:34 pm  ·
Noypi
thanks for the heads up Kamueku Luke Kakizaki. Which one should I go with? RGB or CMYK? Can I make these changes in Indesign or do I have to go to each individual file?
Dec 25, 12 2:23 am  ·
Kamu Kakizaki
for digital portfolios RBG. chose like sRGB when exporting. if you see individual images inconsistant check the linked file. CMYK is for printed portfolios (sad not may school are asking for these nowadays)
Dec 25, 12 2:44 am  ·
