3d autocad to illustrator
won and done williams
this is a dumb question, but i'm trying to open a hidden line 3d autocad view (dwg) in illustrator (ai). whenever i open it in illustrator i get a 3d wireframe, not hidden line. there must be an easy way to do this, and i'm just missing something.
Aug 28, 07 8:37 pm
or i could have just used the search function.
we all get desparate and make rookie mistakes.
Aug 28, 07 9:10 pm  ·
garpike
666
Aug 28, 07 9:30 pm  ·
binary
print to pdf
Aug 28, 07 9:42 pm  ·
Gabriel Duarte
Open your DWG file in Rhino and use the MAKE2D command. You'll generate a bi-dimensional vector image of the perspective view of your choice with the hidden lines you want...you can even SAVE AS your results straight in AI format.
Aug 28, 07 10:43 pm  ·
mea culpa, mea culpa, mea maxima culpa
Aug 28, 07 10:47 pm  ·
Jonas77
ya open in rhino make2d and save as AI from rhino. what Gabriel said
Aug 29, 07 1:40 pm  ·
poster
autocad has a flatten command that will flatten 3d to 2d. it is interesting because it will flatten based on the view and project the 2d in that 3d view. give it a try
Aug 30, 07 3:20 am  ·
psycho-mullet
I think it's called solprof
Aug 30, 07 4:35 pm  ·
as cryzko said, print to pdf.
set up your view in paperspace.
double click your viewport to bring up it's properties and set the shade plot setting to hidden (not 3d hidden because it will give you a 2D image).
plot.
done!
Sep 3, 07 5:46 pm  ·
binary
plot to the largest size you can...... so the image comes out better as a .pdf/.jpeg
b
Sep 3, 07 6:36 pm  ·
trace™
probably another stupid question
how do you print to PDF if you don't have a printer setup (no plotter here)?
Sep 3, 07 9:02 pm  ·
maybe we should just call this the dumb autocad question thread.
trace, you will have to set up a postscript plotter, then plot to file. this site will walk you through the set-up.
Sep 3, 07 10:12 pm  ·
binary
look for "cute writer" it's a pdf setup....... comes with a "ghost converter" for translating to pdf also..
b
Sep 3, 07 10:19 pm  ·
Jonas77
make2d in rhinoceros still does the best 2d creation from a 3d view and provides the option to not need neither autocad or illustrator for future use ;)
Sep 4, 07 12:16 pm  ·
psycho-mullet
I use the cute writer works great.
Also acrobat pro comes with a PDF writer.
Sep 4, 07 5:04 pm  ·
PerCorell
"how do you print to PDF if you don't have a printer setup (no plotter here)"
There will alway's be a "plot to file" check box , then when you plot a file is written --- just check where that is stored than import that file into the document. In fact any graphic format would work , so don't care if it is a Jpg or a Pdf file you "plot" , rather make as file ; just check what illustrator accept of import graphic file.
Sep 5, 07 5:04 am  ·
