unfolding maya poly surfaces
Gordon
is there a way to snap a poly plane flat to the grid in maya, if the origial orientation is in space in some random configuration?
i want to do this manually first, then maybe use an unfold script.
Aug 23, 07 8:15 pm
anotherquestion
i think it's easier export poly surfaces to rhino as an obj file, then convert meshtonurb in rhino, and unroll surfaces in rhino
Aug 23, 07 9:25 pm  ·
grid
or use pepakura
Aug 24, 07 12:57 am  ·
PerCorell
I must warn to export to Rhino for unfolding, --- unfolding shuld work with entities created in Rhino , I don't know how complicated though --- but Rhino don't accept unfolding of AutoCAD meshes so maybe Rhino only accept it's own mesh entities.
Aug 24, 07 6:12 am  ·
poster
in 3ds you can get the unfold info from a channel...
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=5582146&linkID=9241177
there may be a similar way in maya
Aug 24, 07 12:19 pm  ·
French
rhino can convert a mesh into a nurbs that can then be unfolded
Aug 24, 07 12:27 pm  ·
PerCorell
Cyber-Boat ;
http://groups.yahoo.com/group/Cyber-Boat/
Free plans from unfolded polymeshes since 1989
Lapstrake planking , clinker build .
Aug 24, 07 1:36 pm  ·
grid
pepakura
pepakura
pepakura
pepakura!!!!!!!!
Aug 24, 07 2:38 pm  ·
rehiggins
Lamina works well too, even creates a PDF that shows you how to assemble the unfolded pieces as well as taking into account the thickness of whatever material you'll be cutting the design from…
Lamina Design
Aug 27, 07 2:38 pm  ·
