When writing scripts what do you type to replace the particular geometry name (nurbsplane1) to initiate the script on any object selected later?
I'm doing a bit of work and hoping to copy the scripts from the editor and then paste it into a button that will work on any selected geometry, not just the geometry I initially used.
Maya Scripting
Maybe some Maya guru can enlighten me...
thanks! you rock.
maybe '-relative' ???
There is a paramater in the draw command that names the instance of the object. RTFM.
TFM=POS
