Hidden line in max
Urbanist
Anybody know a fast way to do acad-type hidden line renderings ontop of a max rendering, to accentuate edges? They do this all the time in GSD-work-product, but I never figured out how (other than by using illustrator or photoshop to physically overlay an ACAD hidden line perspective on top of the 3dsm rendering. Is there a rendering that extracts edges and allows them to be differently colored? Any suggestions would be appreciated. Thanks!
May 12, 06 9:43 pm
MMatt
Run through the ink n' paint tutorial. It's a slow render, but it'll do the job. Unfortunately, it's a raster file and not a vector. Otherwise, try a rhino rendering with the isoparms on. It's not a crime to use more than one piece of software to get the job done.
.mm
May 12, 06 9:50 pm  ·
DEVicox
mental ray. you'll be able to get vector output.
May 12, 06 9:51 pm  ·
bRink
set up a camera in max, export to autocad. the saved view transfers so you can just print to eps, and overlay the vector drawing on top of teh max rendering... otherwise there are ways to render hidden lines but not 2d vector files in max...
May 12, 06 9:53 pm  ·
bRink
ok... maybe im wrong
May 12, 06 9:54 pm  ·
Urbanist
Thanks so much. DEVicox, do you know the relevant mental ray settings, for the hidden line effect? Can it work with scene contouring turned on?
May 12, 06 10:30 pm  ·
Christopher Connock
illustrate plugin.
swift3d plugin.
both create hidden line vector format in 3dsmax.
both can be customized to add shading with lines of varying weights, yada yada .. has been mentioned in the forums before - search away!!
May 13, 06 12:09 am  ·
Christopher Connock
ps. mental ray's vector output in max is not too great, illustrate gives you more options.
May 13, 06 12:10 am  ·
Archinecture
another way, (although a bit time consuming) is to (1) group your entire model (2) clone it (3) apply the lattice modifier to the clone and then render both together, looks great every time.
May 13, 06 2:05 am  ·
auvn
you final render plugin
May 13, 06 7:51 am  ·
trace™
Final Render will output a vector, hidden line rendering (with a billion options) via Final Toon (which is an amazing program).
You can output the vector lines, the fills, etc., as any kind of vector format you want. You can make the lines look like anything you want, change thickness based off of angle, shadows, etc. Really, just amazing stuff. Sound intimidating, but if you have Final Render (fToon comes with it), you can get a good image in a few minutes (at least that's how long it took me to get what I wanted).
May 13, 06 9:26 am  ·
crush
There are two ways that I have been able to get the outline look to work- the first of the two works better than the second method.
Option 1: select all of your geometry and do an edit mesh. Select all edges and choose the button "create shape from edges" further down the modify window. Make sure to tick linear and ignore hidden edges. Next you will have to select the new shape or shapes and in the modify tab- rendering pull down, tick "renderable" and give them a thickness. Then just apply a material to the new shapes and render away. The nice thing about this technique is that you can give different shapes different edge thicknesses.
option 2: clone all of your geometry, or only the specific parts that you want to give an edge to, and apply a wireframe material to them. You will have to adjust the line thickness under the material parameters.
Both options require that you render both at the same time- easy!
May 13, 06 9:43 am  ·
Urbanist
Thanks alot for your input... was able to get Final Render up and running in a couple of hours and it did beautiful (if somewhat counterintuitive) renders.
May 17, 06 8:56 pm  ·
