Accessing Xrefs on a fileserver using Mac AND PC
ayer
Greetings Everyone,
Straight to the point:
Autocad xrefs were path'd on a PC to our file server.
Since I'm using a Mac; when I open a file, the xrefs do not show up because the original path was created on the PC.
I can re-path all the Xrefs on my mac, but then when my co-worker goes to open the file on his PC, the Xrefs won't load.
Is their a workaround to this that google is hiding from me?
Nov 7, 11 12:28 pm
ayer
Found a fix...
... now how do I delete this thread....
Nov 7, 11 2:04 pm  ·
Rusty!
you won't share your solution with us? I'll share with you some shrubbery blocks if you let me in on the secret.
Nov 7, 11 2:07 pm  ·
ayer
Honestly, i'm not quite sure what I did...
I found something on the Autocad forums about adding project names.  So In the preferences panel on both our computers I added the name of our fileserver.
Nothing worked after that until I did the next step:
When adding an xref, you must make sure you are using its relative path rather than its full path. ( 3 options are given when importing )
Once again, not quite sure what I did, but the xrefs loaded on my co-workers PC when I opened the drawing file.
Sorry I'm not of much help, i'm tired and my brain hurts.
Nov 8, 11 11:19 pm  ·
