In preparation for my portfolio, the school does not specify page size and asks that applicants format their portfolio for viewing on a computer screen as it will be reviewed digitally. It must not exceed 15 MB. What is the best resolution and page size for a given document?
portfolio
300DPI, standard letter, landscape orientation.
Make sure you use tasteful animations/effects between pages and try not to overdue the sweet Kenny-G jazz background ambiance music.
Devil's advocate: images on a monitor at 100% are 72 PPI. Monitors generally only get so large. Do the math.
Well... I do use Rage Against the Machine tracks to seamlessly blend my folio's pages , so...
300DPI! isn't it too much? Half of that(150DPI) would be sufficient for Monitors. The 15MB limit is always difficult to maintain at 300DPI
1200dpi or bust!
Go for 150 DPI
You can effectively get away with 150-180 dpi
150 dpi for electronic - 300 dpi for printed
consider that moire patterns show up for patterns, diagonals & curves when you target 150 or 72
an image downgraded from 200 or higher will present better on a 72 screen than an image produced at 72
always test your output for the intended use/media
