TU Delft Cgpa
S_M_96
Will I be considered for a place at TU Delft Msc Architecture if my gpa is slightly below required ( they ask for 75%, I have 70%). All other requirements are met.
Sep 29, 19 9:37 pm
osram
This is largely dependent on the country where you are coming from.
TU Delft asks for a 75% minimum GPA but this could translate into a different grade depending on where you're coming from.
For example, the minimum requirement stated on the website for Ghanaian applicants is a Second Class Upper grade (which is 60% in Ghana). Yet the website also states generically that you need 75%.
In Ghana and even the UK, a 75% is a first class.
Oct 20, 20 7:57 am  ·
75 considered first class? way to set the bar low.
85 to 89 is first class here.
Oct 20, 20 8:48 am  ·
osram
It's the same scale, a 70 grade thus becomes equivalent to an 85.
So yeah, you'd find that getting a 70 in these examples (like the UK) is more difficult.
Where's here?
Oct 20, 20 9:01 am  ·
Wall-E
If 75% is required for your country, they accept 70 also if other things are good. like portfolio
Oct 20, 20 2:48 pm  ·
