can you create software that will tame the overinflated egos of our designers?
Oct 21, 18 10:21 am ·
To clarify, we break projects into SD, DD, CD, CA. SD is the most fun, so we spend a lot of time screwing around and making big mistakes. Those mistakes get shoved into DD, where we try to scramble to fix both the design and schedule that was broken in SD. DD can't fix it, so they push their mistakes into CD. CD pushes their mistakes into CA. CA becomes constantly reacting to problems created by everyone else.
Oct 21, 18 10:24 am ·
If software could fix the problems created by not thinking through the pictures we color in SD, everything else becomes easy.
Oct 21, 18 10:25 am ·
arminbroubakarian
Hi curtkram,
Thanks for responding.
Sounds like the project is broken into different phases. How do you guys track what phase the project is in?
Do you guys have a centralized place of keeping track of the project and it's requirements?
Also what is the requirements before the project goes into the next phase (SD --> DD) and does it go backwards if it needs to (SD <-- DD)?
Thanks
Oct 21, 18 10:42 am ·
arminbroubakarian
Do you guys have reviews before the project is promoted to the next phase?
Oct 21, 18 10:50 am ·
at the start of the project we set a fee. the fee translates into the number of hours we have for the project, which is divided by percent into the four phases.
we work out a schedule that defines when each phase ends, and put together a list of deliverables we expect to have at that time. When we hit that date, we issue a set of documents to the project team showing our progress. the review would be of the deliverable set after the project is promoted to the next phase.
Oct 21, 18 11:03 am ·
we use deltek vision for tracking. we have some sort of scheduling software to track the schedule, but i forgot the name. we track a lot of the financial stuff in an excel document, and the deliverable list along with meeting agendas and minutes are tracked through word. we also have newforma, but i don't really use that as much as i should.
Oct 21, 18 11:06 am ·
i think the last question is can phases go backwards. they cannot. however, if SD is incomplete when we enter DD, we have to do the SD work within the DD schedule, which is the problem i started with.
Oct 21, 18 11:07 am ·
arminbroubakarian
curtkram,
Oct 21, 18 11:59 am ·
arminbroubakarian
curtkram, Thanks for answering all my questions. I really appreciate it. You gave me some good information to work with. It sounds like you guys are using multiple tools to track things that should all be tracked under the same tool. The project tracking, scheduling, financial, deliverables, and agendas have a coupled relationship with each other and it doesn't make sense to track them individually. Plus I'm sure having to share excel/word docs with other team members is a nightmare. Unless you guys are using the cloud version. I'm curious why you are not using newforma? Is it another tool that you just don't want to deal with and learn?
The biggest difficulty with workflow is clients. I'd like to see an app that gave direct electrical feedback based on the content of their communication.
"We are going to buy our own appliances and you're not going to get a fee on that." zzzap
"We're doubling the scope of the project but holding you to the original fee." ZZZAPP
"I'm sorry, I can't pay you today because I left my country checkbook in the city." ZZZAAAAPPP
Oct 21, 18 12:50 pm ·
What difficulties to Architects face in their workflow?
I'm a software engineer doing some research on the workflow of an Architect.
what issues / difficulties does an architect face during their workflow?
What tools do you wish existed, that may help you overcome some of these difficulties?
How often do Architects collaborate with each other and how easy is it?
Thank you,
Armin
I like it that you capitalise Architect, makes me feel very special and important.
Hi curtkram,
Thanks
at the start of the project we set a fee. the fee translates into the number of hours we have for the project, which is divided by percent into the four phases. we work out a schedule that defines when each phase ends, and put together a list of deliverables we expect to have at that time. When we hit that date, we issue a set of documents to the project team showing our progress. the review would be of the deliverable set after the project is promoted to the next phase.
curtkram,
