Ceiling joists with no Structural Ridge
Kamil972
Hello,
I have one floor single family house with 2x10 ridge board, the height of the exterior walls is 6-8” can I put ceiling joists at 1/3 of the height ( from the top of the wall to the bottom of the ridge board)
Please advise
Feb 15, 18 6:39 pm
"Joists" are horizontal members and as such would not have a ridge.
Feb 15, 18 6:58 pm  ·
Comments like this is why I stick around.
Feb 15, 18 7:47 pm  ·
Kamil972
By code if you have structural Ridge, you don’t need ceiling joists but if we have ridge board we need ceiling joists, there is one section in the code saying that we can place ceiling joists up to 1/3 of the height
Just want to check with someone about the code
Feb 15, 18 7:08 pm  ·
perhaps you could consult an architect near you?
Feb 15, 18 7:27 pm  ·
Consulting starts at $250/hr. For you, make that $500/hr as a precaution.
Feb 15, 18 7:46 pm  ·
Kamil972
that what I meant by not clear
Feb 15, 18 10:10 pm  ·
Kamil972
Hi Pete,
Feb 15, 18 10:17 pm  ·
Kamil972
Hi Pete,
Kamil972
Where are you located?
Kamil972
I am PE my self but I am trying to help someone I know
Feb 15, 18 10:19 pm  ·
Kamil972
Can you stamp drawings?
Feb 15, 18 10:21 pm  ·
Kamil972
Civil Engineer PE
Feb 15, 18 10:25 pm  ·
That's not building related... stick to making grading plans and turning simple CAD files into Z coordinate nightmares. Hire someone you cheapskate.
Feb 15, 18 10:45 pm  ·
Bench
Wait how does a registered civil PE not understand how to look up something in the building code? F k me thats scary!
Feb 16, 18 2:10 pm  ·
chigurh
civil PE = inner-tube and hot-dog experience
Feb 16, 18 4:43 pm  ·
On the fence
The IRC would allow this.  You still need collar ties in the upper 1/3 as well.  But as long as the ceiling joists are located in the bottom 1/3 AND the rafters are sized correctly due to an adjustment factor (up to .67), its doable.
Feb 16, 18 12:27 pm  ·
It's crystal clear in the IRC, if you know where to look. If you don't know where to look it's probably not something you should be engineering. Since you left out the two pieces of information that actually matter in this case, that's another sign that you should hire a professional.
Feb 16, 18 4:13 pm  ·
arch76
With the top of exterior wall at 6'-8", I guess the doors are on the gable end? sexy.
Feb 16, 18 7:14 pm  ·
Nevermind, I reread the OP.
Feb 17, 18 9:09 am  ·
Medusa
Sounds like a center for ants, but three times as big.
Feb 18, 18 9:52 am  ·
