I need a design idea for this brief but I am super struggling:
Develop an architectural proposition that has care for water at its core and brings this care to wider public attention.
My original design was a small pop up art exhibition of frozen water containing pollution in an artistic way to increase awareness of water pollution. My crit didn't go very well though, and I received a very bad grade. I have been told that my idea lacked complexity. I am now stuck having to decide on a new design idea.
I was once thinking about a perspex shield maybe 1 mile long along a polluted coastline that stops the tins and pollution making its way to the beach. Then comes the tricky aspect of how to collect it and remove it. Something that stops this happening. I know its probably outside of the box, but that is the idea isn't it... Its do able! Making something so big but also invisible is a challenge in itself. Is this even possible? I think it probably is.
How would you increase the awareness of this happening? Well it wouldnt be there anymore for one and you could run little chartered boat trips for a buck a time to see the pile up of rubbish on the "otherside" of the shield.
Seems its already been done, but you could certainly build on this in some way or approach it from a different angle. Aesthetics of the beaches and surrounding areas for example.
you had a bad crit and got a low grade because you did a shit project. sorry Sarah Mosley, you're not going to be able to claim ideas from internet strangers as your own for the duration of a master's program. it sounds like you just don't have what it takes to succeed in architecture school.
The AIA here in NYC has had water and resiliency as a theme for many lectures and exhibits this year. Some of these lectures are available to watch online:
Have you really looked at water as an issue? Yes, pollution is a matter but relative to what. Scooping detritus and muck out of a stream is different from fracking and it's potential to create complex hazardous water "types," or part of biophilic remediation strategies as seen in vintondale pa. Also consider relative to where? Often they're landscape unto themselves
Oct 23, 17 5:21 pm ·
Masters Studio Project
Anyone have any ideas? Really need help!!
How do you contain pollution in an artistic way and how does that increase awareness of water pollution?
I've actually seen something along those lines already..
http://www.thisiscolossal.com/...
http://www.independent.co.uk/e...
Apologies if I am miles off with this.
https://cfa.aiany.org/index.ph...
