Thermal comfort and insulation in an open-space shelter?
John_Red
Hello.
A competition requires us to make a small bird watching unit/shelter in a region that is mostly humid and has a moderate temperature (it is next to the sea). They also want it to be both open-space and for it to provide thermal comfort for the occupants through natural ways (so no air-conditioners etc).
The part that confused us is how to setup thermal comfort in an open-space structure. How can we naturally control (at least to a small extent) the temperature inside an open-space structure if it is not isolated enough from the external environment around it?
Along the way I started losing the meaning of open-space all together. Searches about an open-space shelter mostly show just roofs on columns without walls, completely not isolated from the external environment. How can we provide (and control) thermal comfort in such a scenario? Is simple shading from the sun and the natural wind enough for that?
In the meantime, certain sources define open-space for buildings as simply structures that have defined minimum-sized openings in them that allow for direct sunlight and wind ventilation from the outside.
It confused me. Would a building with glass windows and ventilation shafts be considered open-space? Or do we have to remove the glass on the windows and let them act as simple openings? Or does that not count either and we have to remove a wall or all for the structure to qualify as open-space? How can the last 2 options provide thermal comfort in their case? And does insulation even matter in open-space structures like these?
Unfortunately we cannot ask the competition hosts for more details. I was hoping to get more concrete definitions of the terms related to this project (open-space mostly). I wanted to know, according to a definition, if insulation then matters, and how to provide thermal comfort in that scenario. The information I found didn't seem relevant enough, or not specific enough for our case. I hope that someone can enlighten me or redirect me to relevant sources that can clear the confusion/provide insight.
Thank you and sorry in advance if the questions asked here are rather common-sense. It seems we lack certain fundamental definitions to progress further.
Aug 4, 17 3:30 pm
think alhambra.
Aug 4, 17 3:39 pm  ·
John_Red
Ah, that may be a good starting point, thank you.
Aug 5, 17 3:56 pm  ·
archinine
Competitions such as you described are intentionally open ended. There is no wrong answer. Don't get so caught up in the semantics, just design something.
Aug 4, 17 9:33 pm  ·
John_Red
Yeah, I guess so. It's just that a lot of requirements were mentioned, some that don't fit into bird watching shelters at all. Felt like they wanted a small but fully functional house instead of a bird watching shelter. Oh well, I too think that there is no wrong answer after all.
Aug 5, 17 3:58 pm  ·
Don't google open space structures but bird watching shelters instead. Also, why would anyone put glass in a bird watching shelter?
Aug 5, 17 7:58 am  ·
