Amd chips for revit?
gruen
anyone use high end amd fx series chips for revit? I need to get a desktop machine and the prices are enticing.
Mar 4, 16 8:49 am
gruen
PS-this would be for small scale projects. Models ~75 mb max
Mar 4, 16 8:50 am  ·
archiwutm8
Basic Revit will run on your grandma's computer, I'm sure a high end AMD CPU will work. Although I'd tend to stick with Intel cause if you call Autodesk up and tell them you use a AMD chip they'll just say it isn't support and you should of gone for a Intel.
I worked with Autodesk technical support, this used to be the most common thing that happened.
Mar 4, 16 8:54 am  ·
inb4rickroll.
The AMD chips are actually quite fast for single-threaded applications. I have a home desktop with and AMD fx chip and it does fine with rhino, revit, adobe, etc... That said, so would an Intel i-5, and the price difference between those two is rather negligible. The Intel will have much better multi-thread compatiblity with different software and probably run better overall. Look up "antitrust lawsuit Intel AMD compiler"
Mar 4, 16 9:15 am  ·
Dangermouse
I've used an FX-6300 with revit and had no problems.
Mar 4, 16 9:26 am  ·
legopiece
Amd will work just fine it will also leave you extra cash for graphics card, ram, storage, monitors i use amd fx no problems
Mar 4, 16 10:59 am  ·
gruen
Great-thanks all.
Mar 4, 16 1:04 pm  ·
