Anyone Know What This Specifies?
frankwil
I know the 65 degrees refers to the angle, but is the 45' a further incrementation of a degree, and if so, how is it calculated? What would the decimal value be?
This is from an architectural drawing from the 1930's.
Thanks in advance.
May 16, 15 1:38 pm
"is the 45' a further incrementation of a degree...?"
Yes. It indicates arcminutes. One arcminute is 1/60 of one degree.
May 16, 15 1:54 pm  ·
JeromeS
Called minutes, often accompanied by even smaller declination; seconds
If you use autocad, you can enter angles as follows:  45d37'12"
May 16, 15 9:41 pm  ·
awaiting_deletion
which makes Bucky Fuller a genius....roaming library stacks i couldn't believe 1/60 was rational but it goes back to the Sumarians, and if you are into Ancient Aliens, basically Aliens...why 1/60 and why does PI even exist....
http://www.rwgrayprojects.com/synergetics/synergetics.html
May 16, 15 10:17 pm  ·
boy in a well
pi is just math's way of saying round.
May 17, 15 2:27 pm  ·
awaiting_deletion
round and round and round and round and round.....
May 17, 15 3:04 pm  ·
