I've always defaulted to Arch D, 24x36, because that's what I was taught. But the more I think about it, ANSI D makes alot more sense, especially when you can print out a true half size set on 11x17. Any thoughts on either size. I know a lot of you probably use 30x42. Not an option here.
Interesting look at it. For my work (residential) I'm using 24x36. I've done a planning module that works on other sheets, but not considered how it might work if I started w ANSI D
My prior work experiences have all used the 24x36/12x18 sizes but the current firm I work switched to ANSI D and 11x17 half set right before I arrived. It makes sense cost-wise and there's really no difference fitting things layout-wise. I like being able to print half half-sets at 8.5x11 for quick sketching over of plans & sections.
The firms I worked for always used 24x36 and 30x42. We ended up buying 12x18 paper to print 1/2 size sets for in house use. That is very expensive paper too.
I like the idea of using the ANSI D paper size, especially if there is a cost savings. It makes sense to me.
My standard sheet size is ANSI D (22x34), but I have a hard time convincing engineering and other design professionals on the team to use it. (Most use ARCH D 24x36).
And, yes, I'd welcome a decree that we shall all use A-series ISO sheet sizes.
hello. i have a question. I am using Aveva E3D Draw for creating a drawing and the template we are using for the title block is size ARCH D. we need to print it to PDF using ANSI D size. will it mess up the drawing scale changing from 36x24 to 34x22? Thanks in advance for the help
Mar 29, 24 4:30 pm ·
Obviously, yes.
Mar 29, 24 5:44 pm ·
Arch D or ANSI D
Just noticed that the revit default is 22x34. Since revit can draft better than me I will go with 22x34 ;)
Wow i'm shocked that you use the same terminology to describe 24x36...is that just an overall rule of thumb for autodesk itself?
Our large projects are on A0 sheets (841mm x 1189mm) but most are A1 (594mm x 841mm)
Silly America and its outdated measurement religion.
Obviously, yes.
