Rhino question: faceting a complex curved surface
tagalong
I'm working on a project that will ultimately be fabricated out of water jet cut steel plates. In my rhino model, I currently have a complex curved surface modeled, the closest explanation of the shape would be a little less than 1/2 a water droplet if you cut a section through it. I am wanting to triangulate a series of simplified planar surfaces, recreating an abstracted version of  the curved form out of about 8 surfaces (as opposed to a more literal copy of the form which would require hundreds of surfaces at least).
Does anyone know of a method or command to generate this process in rhino?
Thanks..
Oct 5, 11 10:13 am
dionysus
hey, if you haven't yet tried grasshopper, it sounds like this project would be a good exercise in it.  you should direct your question to the grasshopper3d.com community...there is a ton of resourceful people there!
Oct 5, 11 1:16 pm
rehiggins
the paneling tools (free) should also be able to handle this
Oct 5, 11 1:19 pm
brorstein
Yeah, if turnaround is quicker, I'd suggest paneling tools as well.  It's a little more forgiving on the learning curve.
Oct 5, 11 3:08 pm
tagalong
thanks for the info, paneling tools looks like it's going to work, i'm trying to jump into grasshopper for patterning the surfaces...
Oct 5, 11 3:38 pm
empea
Did you try meshing directly in rhino?
Oct 16, 11 1:36 pm
Apurimac
try meshing with a low polygon count
Oct 17, 11 10:10 am
kunalghevaria
What did you finally do? Reducing poly count in max would also have worked.
Dec 9, 11 3:38 pm
