Code and Min. Parking Stall Dimensions
BulgarBlogger
Aside from ADAAG, does the code list any minimum dimensions for commercial parking lot stalls?
Thanks.
Oct 26, 16 10:48 am
Zoning codes do.
Oct 26, 16 10:50 am  ·
senjohnblutarsky
Typically, it is a local issue.  Not specifically addressed in the IBC, but IBC references ANSI A117.1.  So, you also have to note the requirements for accessible spaces there.
There is an International Zoning Code.  But I don't know how widely adopted that is.  Check your local zoning/planning ordinance.
Oct 26, 16 10:56 am  ·
JeromeS
zoning
Janosh
Local zoning, which is extremely variable from place to place as to its requirements. I've had projects where minimum stall widths from 7'-6" to 9'-6". I can't wait until we are post-parking.
Oct 26, 16 11:31 am  ·
shellarchitect
state ada code may specify handicapped parking sizes along with loading areas and required counts
Oct 26, 16 12:00 pm  ·
x intern
Don't do minimum parking sizes. At least here in Texas they don't work for SUVs and trucks
Oct 26, 16 12:46 pm  ·
Most counties have a parking design manual
http://www.sandiegocounty.gov/dplu/docs/Parking_Design_Manual.pdf
Oct 26, 16 1:01 pm  ·
That's why it's a local zoning issue. What works in New York might not work in Texas, etc.
Oct 26, 16 1:31 pm  ·
shellarchitect
just completed spa for a retail development where the city would not allow spaces larger than the min. allowable.  Had to change all our 10x20 spaces to 9x18
Oct 26, 16 2:59 pm  ·
standard is 2.6m x 5.2m here which is smaller than your typical 9x18.
Oct 26, 16 3:24 pm  ·
So your parking is smaller just like the spending power of your dollar?
Oct 26, 16 3:36 pm  ·
Is that not how it works?
Oct 26, 16 4:26 pm  ·
drums please, Fab?
Ooooooo-SNAP!
totally local issue.
Chicago allows 8' wide stalls (x 18' long) when the drive aisle is at least 22' wide.
Oct 26, 16 4:45 pm  ·
