Portfolio Exporting
international_applicant
Hello guys,
I am finishing my portfolio and I struggle to meet the MB asked by the univeristies for the portfolio PDF submission. I am working InDesign and I have checked forums, saw videos on Youtube etc. Here's the question: what are the best specifications so I minimize my PDF exported file size without damaging severely the quality of my work?
I already have the minimum 150 dpi asked but still get smth like 25 MB when my submission asks for smth like 15MB or even 10MB. Any ideas? Any past applicant here?
Thank you in advance
Nov 21, 15 6:52 pm
Spoons
A good way to minimize size is when exporting as pdf (or within Acrobat) to make it only compatible with newer versions of pdf readers.
See this screenshot for where that option is located:
http://www.greenerprinter.com/grp/b-images/PDFPrep_InDesign3.gif
I think by default it is compatible with versions of acrobat from many years ago.  A quick google will tell you when versions came out and you can make the decision for how far back you think you should go.
Nov 21, 15 7:27 pm  ·
FlameAura
Hey, I have exactly the same problem. I found out that what makes my file heavy is vector linework from Illustrator and pdfs. On the other hand vectors look sharp and nice, unlike bitmap jpgs. Do you know if there is some solution which would somehow keep the small size and nice linework?
By the way- I was told that the best way of exporting&small size is Pdf - Interactive- that's what I am doing already, maybe it will help someone too
Nov 21, 15 7:58 pm  ·
Anonymoose
For vector linework in Illustrator:
Keep your artboard sizes small. If your diagrams are too big, scale them down and adjust your lineweights accordingly. Save all the diagrams as separate PDFs and choose "Smallest File Size" and disable all editing options. Link these to your InDesign file. Should shave off a few MBs.
For raster images in Photoshop:
Always start off with a ppi of 300. At that pixel density, you don't have to go beyond a resolution of 3500 x 2500 even for a full size A4 image. For smaller images which won't cover your whole page, reduce your resolution but preserve the ppi. While saving, save it as JPG and choose a quality between 8-12, depending on the density of information. If it's just flat colors, you can even get away with 6.
InDesign:
When you're saving your final PDF, choose "Smallest File Size" and in the Compression tab to the left, downsample anything above 225 dpi to 175 dpi for online PDFs. Keep Compatibility at Acrobat 1.7 or newer. If you're printing, preserve the 300 dpi.
Nov 22, 15 12:43 am  ·
natematt
Use the print function to create the PDF rather than the export function. This should help.
Nov 22, 15 2:41 am  ·
FlameAura
thanks guys, I'll try those things out
Nov 22, 15 1:37 pm  ·
Me too guys! Sounds like a good start!
For all of you saying that I should export my file as a compatible file with Acrobat 1.7 or newer, are we sure that the admissions' computers have adobe 1.7 or newer? :)
Or are we going to end up with a small pdf, what won't be able to be seen?
Nov 22, 15 7:04 pm  ·
Spoons
The original version 1.7 of the PDF format was released November 2006.
Nov 22, 15 7:06 pm  ·
Ok good to know Spoons! Thank you all for your support! Hope the best to fellow applicants
Nov 23, 15 7:07 am  ·
