CANE DETECTION GUARD SUBSTITUTE
bentropy
hey all
does anyone know if the 27" max rail to block off overhead hazards for the visually impaired can be substituted with a curb? does the rail have a min height?
Jul 21, 08 3:33 pm
el jeffe
ansi a117 doesn't specify a minimum but it does use the words "guardrail or other barrier"
it'll be an interpretation question for the code official as to whether a 4" curb is a barrier.
Jul 21, 08 3:57 pm  ·
Janosh
It has been done. As El Jeffe sez, it is subject to the whims of the authority having jurisdiction. Shudder. Frank. O. Gehry, FAIA, got away with negative "floor braille" at the Disney Concert Hall. And I can't imagine that it would work as intended.
Jul 21, 08 11:21 pm  ·
holz.box
janosh - nice call on the disney hall...
the concrete is [hammered?] where the wall angles out
here's a pic for those that haven't seen it...
i've seen short rails,OMA's seattle library has them
Jul 22, 08 12:14 am  ·
bentropy
holz, you are by far the most helpful poster in the history of archinect. keep on rockin.
Jul 22, 08 1:23 pm  ·
holz.box
i think it's the only thing that lets me stay sane...
Jul 22, 08 3:44 pm  ·
bRink
Calatrava's Milwaukee Art Museum has probably the most elegant cane detection I've ever seen:
Here's tricky with wheelchair access for a grade change, but still pretty sweet:
Jul 22, 08 10:14 pm  ·
ross
have seen a school where the bottom few risers and area under the upper steps was cast from concrete. not more than about 18 inches high. the rest of the staircase was wood and steel. made for a decent bench below the stairs. not sure of the project. wasn´t anyone that well known.
also, at steven holl´s MIT housing, there is a low metal rail that doubles as a magazine rack. not necessarily elegant, but it passes.
Jul 23, 08 9:59 am  ·
