Hi, I am new to this forum. I need some advice on how to build a staircase between 2 parallel supporting walls while the 3rd main wall is at an angle to these walls. See the attached image to get an idea. The challenge is, none of the steps should be tapered down. All the steps should be rectangular in shape.
If this question doesn't belong to this forum, kindly ignore it.
How to build a staircase against slant wall?
TIA.
spiral
Carefully
draw it at smaller scale so there is more room
easy, have it float between the walls.
There's probably 50 ways to do this, here's the least interesting one:
SSTduds... if you have this much free time on your hands, can I get you to do some free work for me?
You can get 90 seconds of free bluebeam markup anytime you want, Non.
very tempted...
