Registration for architectural licensure in Oregon (new rules to pay attention to) as of February 2020
RickB-Astoria
Regardless of licensure path, direct in-state registration or reciprocity, AXP hours must be earned through working under an architect. AXP Portfolio method is not accepted. If you earn your AXP via AXP Portfolio, you maybe required to redo AXP hours until you have the required AXP hours completed in the approved method.
It doesn't matter if you are NCARB Certified. Pay close attention to OAR 806-010-0010.
Posted below is the important text. This applies to the other rules on registration by examination and registration by reciprocity.
806-010-0010 Approved Architect and Firm Registration and Evaluation Programs
(1) The Board adopts the education standard adopted by the National Council of Architectural Registration Boards (NCARB), consisting of a professional degree in architecture from a program accredited by the National Architectural Accrediting Board (NAAB) or the Canadian Architectural Certification Board (CACB), or a professional degree in architecture certified by the CACB from a Canadian University.
(2) The Board adopts the requirements in the document titled NCARB Architectural Experience Program (AXP) Guidelines dated July 2019, with the exception of documenting experience through the AXP Portfolio, for the experience requirement for registration.
(3) The Board adopts the Architect Registration Examination (ARE) 5.0 prepared by NCARB, and previously adopted versions of the examination, as the approved examination to test applicant qualifications for registration.
(4) The Board adopts the requirements in the document titled NCARB Architect Registration Examination 5.0 Guidelines dated July 2019 for the Architect Registration Examination (ARE).
(5) The Board adopts the requirements in the document titled NCARB Certification Guidelines dated July 2019, with the exception of documenting experience through the AXP Portfolio, for the NCARB Certificate under OAR 806-010-0035(3)(f)(A).
(6) A person may be considered for registration by the Board by satisfying:
(a) The rules for registration by examination under OAR 806-010-0020; or
(b) The rules for registration by reciprocity under OAR 806-010-0035.
(7) A firm may be considered for registration by the Board by satisfying the rules under OAR 806-010-0080.
(8) To pass the Jurisprudence Exam (JE) an individual must do the following:
(a) Complete the JE within 90 minutes.
(b) Score at least 84 percent.
(A) An individual who fails the JE must wait seven days before retaking the examination.
(B) Test results are final and binding on the applicant.
[Publications: Publications referenced are available from the agency.]
https://secure.sos.state.or.us/oard/viewSingleRule.action?ruleVrsnRsn=266294
Feb 12, 20 4:56 pm
interpol
Thanks for the information, good to know!
Feb 12, 20 6:27 pm
RickB-Astoria
It is worth letting people know so if they use that AXP Portfolio process that they may run into problems with registration or reciprocity (even with NCARB Certificate) in Oregon.
Otherwise, they would have to go back through earning AXP hours the traditional way in order to get their hours and license to practice in Oregon even though they maybe licensed in another state that accepts AXP Portfolio.
Feb 12, 20 7:03 pm
