new architecture students read this outline of materials & methods
JawkneeMusic
Arch e materials & methods
Creep=to evolve shape over time
Fatigue=to break due to cyclical loading
Hardness=strength against indention from an impact force
Stress/strain=induced amount of static pressure/reaction to this pressure
Moment=the area around which an object, when thrown, will rotate
Natural mode of vibration=think of a pendulum, a beam acts in the same way under earthquakes, if you hit it while it’s going in one direction it goes farther, and will eventually break
Gust=a momentary static pressure, caused by perhaps wind
Caternary=the shape of a string held between two points
Truss=a pinned collection of joints, meaning it can rotate but not slide
Frame=a rigid truss, examples being welding
Rivet=metal inserted while hot to pin a joint
Young’s modulus of elasticity: the graph of stress/strain
Compressive force: a force that pushes a beam together
Tensile force: a force that pulls a beam apart
Bending: related to shear, it is the bowing of a beam
Shear: the pushing sideways of a beam
Buckling: The bowing of a beam due to compressive forces
A beam can be assumed to not be affected by its own weight
There is a point for steel, and for concrete where the stress & strain are linear
Rivets have high fatigue strength
Welds must be calculated both at the chemical level & the equipment level
Learn about 3-phase electrical
Masonry arches of any sort must fit inside a caternary
Post tensioned masonry: a type of structural wall that has post-tensioned steel clamping it down (uses less grout), has less rotation, thus better in earthquake zones
Steel: said to be anisotropic but can be assumed isotropic with young’s modulus of elasticity probably
Concrete is weak in tension but strong in compression so can be mixed with steel at certain points to cause equality
Masonry is reinforced just like reinforced concrete
Wood is anisotropic so Roark’s Formulas for Stress & Strain don’t work on it, you will have to probably you Structural Analysis (matrices), or materials & methods
Roark’s Formulas for Stress & Strain has the most up to date besides atomistic stress/strain, impact, vibrational
The Timber Manual by the U.S. Forestry service has formulas for angled stressed wood
When a beam undergoes a slanted force, I believe you can assume this force is superpositioned into its vectorial components
For vibrations there are dampeners
Dec 11, 18 8:35 am
This was covered in my 1st year civil p.eng class.  Nothing new here kid.
Dec 11, 18 8:37 am
tintt
about 1/1,000,000 of what you need to know to be an entry level architect
Dec 11, 18 8:39 am
You forgot E=mc2
Dec 11, 18 11:04 am
tintt
The most important one is the sum in the x,y, and z planes all must = 0!
Dec 11, 18 11:32 am
Again, the career you're looking for is 'Structural Engineer'
Dec 11, 18 1:06 pm
