I recently took over as the controller of a small architect firm, and we are moving from the Quickbooks/Excel method of billing and bookkeeping to a Deltek solution. As we are not importing all of our historical data and, in effect, starting a new system from scratch, this is a good time to start fresh on "the way things have always been done".
The project numbering system in place is our files are coded YYMM##. The first project created this year was 170101, the second 170102. When we hit February, it was 170201, 170202, etc.
The problem lies with the fact that we are in a fast growing area, and we are getting a lot of repeat customers (bank branches, housing developments), etc. I have one bank that has projects with us spanning 5 years, so we may have 130207 -Bank Name - Branch Name; 141001 = Bank Name - Different Branch Name, etc.
Since we sort by the number, the files are in different locations.
Does anyone have a project categorizing system you really love? Do you find it effective to keep the top level of a category by customer name, or have some other method?
Here is what we do and it works quite well. - even with using time tracking. Granted this was up to 15 employees and 100 projects per year. Your situation could be different.
We use 2017-001 then 2017-001.01 for major revisions or scope change. We have domain level names for repeat clients then "add a Job" underneath.
QB Example:
Car Guy 2002-003 Remodel, City 2006-009 New Building, City 2006-009.02 New Building, City, Value Engineering 2006-009.03 New Building, City CM Services 2010-072 Tenant Finish, City
Then when re run a report of just the client name we see their lifetime value.
Digital files are always by project number and use a standard directory tree underneath.
In Quickbooks, we start with client name, and then the jobs under each client. We use four-digit numbering for our projects, by year: YY##. Project folders and all files keep the same numbering. We don't number our clients. It works fine. We've had several cases where the project changed client mid-stream. We were able to keep the project number, even though the invoicing moved to a different customer account.
Jul 1, 18 6:27 pm ·
Project file numbering system
Happy Friday, everyone!
Thanks!
oops - Missed you were going cloud:
QB Example:
Car Guy
Good Luck
The full project name is NUMBER-ADDRESS-CLIENT NAME
Therefore it's
17001 123 Main JOE BLOW
We can search by client name & address.
Seems to work for multiple projects on the same building.
whats this mens?
because of reasons.
Why i have this project number for?
Historians.
to be somewhat organized!
We do point numbers too...18105 for the building itself...then tenant or revisions get .1, .2 etc.
