Quick question about finishing interior CMU walls?
l3wis
Heya,
I had a fast question about methods for finishing a basement with concrete masonry (CMU) walls. What options are there, exactly, in terms of finishing this kind of surface? I'm really only familiar with two...
Drywall
-either attaching on furring strips or by putting up a stud wall
Stucco/Smooth Plaster
Are there other alternatives for a space people will live in? What's the cheapest option? I guess I need to weigh appearance versus insulating effectiveness versus cost. Thanks for the quick replies.
Feb 27, 10 11:22 pm
holz.box
you might want to insulate those walls... otherwise you'll be heating the backfill.
Feb 28, 10 12:05 am  ·
dlb
assuming you are considering furring strips or a stud wall, then there is almost nothing you can't finish the surface with:
- wood paneling
- stone veneer
- glass or mirrors
- seal and paint the CMU
etc...
Feb 28, 10 4:33 am  ·
minimalista
If you intend to leave the walls exposed and uninsulated (although I'm with holz - insulation is probably the best option), the gold standard for concrete and CMU paint is a company called Tnemec (cemenT spelled backwards) http://www.tnemec.com/
Feb 28, 10 10:13 am  ·
poop876
I had bunch (a lot) of ceiling tiles laying around at my fathers shop. So I screwed boards to the wall and glued the ceiling tiles on top of them and then painted it. Looks pretty cool, gives it some insulation and it was free!!!
Mar 1, 10 10:19 am  ·
BUILDERGUY
If you didn't waterproof the foundation walls I would be very leary about installing plaster or using lath and drywall.  Too easy for vapor drive or a leak to cause a mold problem.  If you did go to the trouble of installing a real waterproofing product such as Laurenco then you can do just about anything you want.  If you didn't I would suggest painting with Tnemec or maybe using something like Eldorado stone adhered with epoxy.  Tnemec will allow the wall to breathe.  The thin set stone will as well assuming you spot apply the adhesive.
May 21, 16 11:07 am  ·
