check with your local commercial glazing installers. limits on size is cause of several factors - transportation limits (gotta fit on a truck), the size of the annealing/tempering ovens, and furnace widths (typically in the 10-12' range). Wind loads will determine thickness of glazing unit, and orientation will determine coatings/solar-shading coefficients/tinting/u-value. Some of the coatings have size limits depending on how they are applied.
typically 10' x 5' is easily sourced, some places can provide 10'x10' or 12'x6'. the better/higher end folks will provide bigger glass (pilkington, schott, ppg etc), while local yokals will be limited to much smaller glass installations.
structural glazing (laminated glass/tempered) with butt glazing can produce an interesting look too, but takes more engineering.
140 Inches wide by any length you can successfully transport from the mill to the site. I think 140in x 360in was the largest piece of glass ever installed in a building...
At the monta ray aquarium there's a glass wall in their main tank that is made of several pieces of glass that are fused together somehow by a japanese company. Apparently they have some proprietary fusing system that they're pretty secretive of (at least at the time of the project). It was a while ago and unfortunately that's all i know about it.
Check out the Boston Federal Building. I think it was done by Hugh Stubbins. I think they suspended the glass cause it could not carry its own load. There is also a Native American Museum in British Columbia which was done by Arthur Erickson where he had some wonderful glass walls, but it might not be the look your after, but well worth the effort and research. GO BIG GLASS!
Kempe Thill have been experimenting with welded acrylic glass (see the Franz Liszt Konserthaus), with sizes up to 18m x 4m (yes, 700" X 160"). I'm not sure if this can be done as double glazing, otherwise heat insulation would be an issue.
A professor told us in a review this past spring that the only country that produces big glass panels (larger than what the typical factory can float) is Germany. I'm pretty sure I remember reading that those panels on the new Apple store on Fifth Ave were shipped from Germany...super expensive.
Mdler,
You're right. The glass pieces Apple used were from China supposedly. I just looked into it and an article said that until recently, Germany was the only country able to do it. I guess the professor who told us that was a little out of date. Anyways...shipping panes from China or Germany would be equally expensive.
BIG glass
I'd like to incorporate an unusually large single window using typical commercial glass/framing. No divisions. No butt glazing. Just one big window.
Business occupancy. Window would be located at the second story in an "untouchable" spot - that is, no one could mess with it without a ladder.
Beefing up the perimeter frame is not a problem...7"....8"....wider still?...all OK.
Anyone know what the size limit is? Ideas?
..k..
are you ready to spend $$$$ for this window?
Treekill and Pocz -- thanks, that's a good start. Mainly I hear from the locals ONLY about what "can't" be done!
140 x 360? That's a hunk o glass.
Mies was building stuff 3m x 9m in the 1930s. ANd it retracted into the floor!
yeah but look where mies was. czech republic is land of incredible glass making history. that is if you are referring to the house in brno...
We have already installed a peice of glass 124" X 546" in Canada and are available for installations and consulting.
look at BCJ's Apple Cube
I think China has the capability as well
Mdler, You're right. The glass pieces Apple used were from China supposedly. I just looked into it and an article said that until recently, Germany was the only country able to do it. I guess the professor who told us that was a little out of date. Anyways...shipping panes from China or Germany would be equally expensive.
sounds like the real question is how much $$$ you have to spend on the glass
