Balcony Questions?
BeangukEXE
Hi, I'm just a high school student, but I'm looking to get into architecture. I've started on a project, and I wanted to know a few things about the balcony. How big can a balcony be without having a post underneath it? And if so, how big would the post be?
Also, I don't really know what type of category this would fit into, if anyone could direct me to the correct place, that'd be great.
Any feedback would be great!
Jan 22, 13 12:46 pm
Thecyclist
I'm guessing this balcony will be built and supported by wood...?  Will there be any heavy objects placed on the balcony...?  Large planters, furniture, hot tub, large grill, etc...?
It sounds like you're asking how far a balcony can cantilever before it needs to be supported by a column(s).  Using the widest typical lumber dimensions found at the usual hardware stores...I'm guessing that's a 2x12.  To take advantage of the structural integrity of the board, they should be placed with the long dimension standing vertically.  The denser the placement, the farther you can cantilever...but because it's wood, I wouldn't go beyond 5 feet.  If you do go to five feet, maybe place them at 1 foot on-center.
Jan 22, 13 2:00 pm  ·
if one end is fastened to a house at the second floor against a rim joist or something, then you need a post or some other sort of structure to hold up the other end even if it's 4" wide.
if you have two support points holding a 2x12 beam/joist at the back, there is a rule of thumb that you can overhang about 1/3 of the member length.  if your beam is 15' long, then the back 10' has to be supported and it can overhang about 5'.
if it's wood, the post would be a 4x4, unless for some reason it was a 6x6.  if you cut a notch in the post to set a beam or joist on, you probably want a 6x6
draw a picture of what you're trying to figure out and post it.  it might help.
Jan 22, 13 2:09 pm  ·
snook_dude
You should also consider Snow Loads, Drifting Snow loads, and comfort levels.
A deck can get kinda bouncy and well it might be safe but it doesn't feel that way due to the deflection.
Jan 22, 13 5:03 pm  ·
Rusty!
Your balcony can be as cantilevered as your imagination will let it be!
Jan 22, 13 7:00 pm  ·
i raise your fancy cantilevers with a cantilevered balcony on a cantilevered building
Jan 22, 13 8:14 pm  ·
Rusty!
I guess possibilities are endless in OKLAHOMA.
Jan 22, 13 8:19 pm  ·
aphorismal
Will, what building is that?
Edit: Nevermind, MVRDV's Wozoco housing for whoever else is curious.  It's even cooler from the either side...
Jan 22, 13 10:25 pm  ·
BeangukEXE
In this house that I'm planning, the balcony is 15-6 feet wide and 10 feet deep(It's a pretty big house), and I don't know much about cantilevers... Can someone fill me in...? What kind of support would I be needing?
Jan 23, 13 10:42 am  ·
i like the term overhanging beam.
http://www.aboutcivil.org/Determination-deflection-over-hanging-beams.html
this is what i think of as a cantilever:
http://emweb.unl.edu/Mechanics-Pages/Scott-Whitney/325hweb/Beams.htm
or, to simplify the illustration and give you a thing to test at home;
Jan 23, 13 11:09 am  ·
gwharton
If you look at the first of curtkram's diagrams above, you'll see the typical cantilever setup: a larger portion of a beam supported in two places ("developed length") with a cantilevered end. As a general rule, the ratio of the supported to unsupported parts of a cantilevered beam like that should never be beyond 1/3 cantilevered length for 2/3 supported length. That's true for slabs as well. Obviously, you can do otherwise with heroic structural engineering and more exotic systems or materials, but the 1/3:2/3 Rule will keep you in known territory until your cantilevered length gets beyond six feet in wood, 8 to 9 feet in concrete, or 10 feet in steel.
Beyond that, you need something special. Diagonal supports at least, or possibly high-strength materials and truss-work.
There's also a complication with using an embedded beam or slab this way as part of a cantilever system: leaks. Any time you have a beam or slab that extends continuously from interior to exterior like that, you've got a prime candidate for major water intrusion problems. Because of that, you'll usually see cantilevered slabs stepped at the boundary of inside to outside, and beams need to be extensively flashed around the hole they make in the building envelope.
So, not only are cantilevers more expensive because they require heavier structure to support them, they also require additional expense to keep the water out.
Jan 23, 13 12:30 pm  ·
midweststairs
Currently, our bolt-on aluminum balconies can reach a maximum six of 6' depth x 20' width. These types don't require an embedded beam, or post beneath. The balconies basically attach with knife plates and sag rods. Here's an example of a large size bolt-on balcony
Jun 15, 17 4:47 pm  ·
Cantilever barn in Cades Cove area of Great Smoky Mountains National Park.
Jun 15, 17 5:35 pm  ·
rrpatil26
Not sure if people are still active here, but wanted to check if approx 15' by 7'ft balcony is possible with just 3 columns (and beams) on 3 corners https://photos.app.goo.gl/OoNg...but without 4th column. I mean something like this:
Dec 11, 17 2:40 pm  ·
Raj, hire an architect.
Dec 11, 17 2:56 pm  ·
Try building it in a physical model and you'll know more or less...
Dec 11, 17 3:01 pm  ·
Looks horrible to me; build it.
Dec 12, 17 7:57 am  ·
rrpatil26
Thank you, b3tadine[sutures]! I realized that it is indeed horrible. So I am not going to build it :)
Dec 12, 17 9:10 am  ·
rrpatil26
Thank you David and others. Yes, I am going to hire a local architect (and RCC consultant) who also will ensure setbacks, bylaws are met to get an approval from local authorities.
I wanted to model it beforehand to visualize, understand elevation and feasibility. 4th column can still be on the boundary wall w/o affecting parking width, but that may not be permitted due to bylaws and I personally would like to avoid a column on the boundary wall.
Dec 11, 17 9:58 pm  ·
Just for the sake of architecture and the mental health of architects, don't give this model to the architect and tell them to make it buildable or up to code.
Dec 12, 17 2:12 am  ·
rrpatil26
I agree with you "randomized". It would be painful for architect to see such poor/non-technical approach to the design and asking them to build it. I am sure he/she would have even better, technically as well as practically feasible design and elevation.
Dec 12, 17 2:37 am  ·
Dec 12, 17 6:36 am  ·
rrpatil26
Dec 12, 17 2:30 am  ·
nolubabalofadana
what are the constraints of a cantilever balcony
Mar 20, 21 1:04 pm  ·
gravity. next question
Mar 20, 21 2:19 pm  ·
