1. One elevator is required for every 45,000 net usable square feet. The ratio of the number of floors to the number of elevators should be two to one or two and a half to one, depending on the occupancy of the building. The more dense the population, the more elevators needed.
2. The number of elevators in a single group should not exceed eight and no single group should serve more than 16 levels.
3. In buildings of four to eight floors, a separate service elevator should be considered. Over nine floors, a service elevator is virtually required.
4. Upper-floor, special-use areas, such as cafeterias, mail rooms, transfer bridges, etc., can increase the required number of elevator
though some resources say per quantity of people not usable square footage.
Zombie thread... But the answer would be a lot, and you'd need express elevators.
While the thread is obviously dead, I want to take a second to recognize that the sport venue question is entertaining. Has anyone ever been in a sports complex that utilized elevators as a primary method of circulation? I have not, and could not imagine it working very well, but I would be entertained if there is an example.
How to calculate the no. of elevators in an office tower of 15 floors,with area of each floor plate is 3200sqm..
what is the formula to calculate the no. of lifts and there capacity.?
Mar 5, 18 4:20 am ·
14 elevators would be normal. You can cut it down to 6 if you have a sign up front limiting only the lazy, fat, and elderly to the elevators. The rest able bodies can use the stairs.
I would decide on the wait time (based on the class of office space) , travel time in the elevator to the office floor and then call up elevator reps and have then calculate it for you often for free. Through a combination of control systems cab dimensions and if you split the elevators to serve groups of floors versus all floors they can give you an idea of the elevator needs. In the US the common code driven requirements are for an accessible route (wheel chair access) and in some places you need one elevator sized to carry a stretcher that serves all floors. Best practice is to have at-least two elevators so you have service if one is out of commission.
determine the number of lifts required for a 15 storey commercial building with a floor pitch of 4.5m, clear door width is 1.2m and the doors opens at a speed of 0.6m/s, selected car has a capacity of 15persons with a car speed of 3m/s and quality of service needed-30seconds
I could not get it right no matter how hard I try, can anyone please help me with my calculations, I have an office building of 60 floors with 1200sqm floor plate area with skylobby at every 15th floor. Thank you in advance
ratio numbers of elevators per area.
hi,
here is a quickie one...
how many elevators would i need for a 12floors, 1800 sq m (5900 sqft) office tower...
anyone know of a chart for this?
cheers
cheers? are you in the UK? aren't egress/code requirements different there? You should look it up...
what cheers is just for uk?
i am not in Uk.
just want to know the rule of thumb
There are rules of thumb to determine the number of elevators required:
http://elevatoradvisors.com/first.html
Office buildings:
thanks mate
lol, mate.
i really meant that if you are British the rules might be different, not that Americans (or whatever you are ;) can't say mate.... dude.
But how do I determine the number of elevators in a Sports Complex with approximately 50000 audiences?
50,000 audiences of how many people?
No such thing as a rule of thumb for elevators in residential.
The number of rooms, the unit mix, the target market, and the floor plate area all factor into the game
hi,
how many elevators would i need for a 59 floors, 5000 sq m (53829 sq ft) office tower...
anyone know of a chart for this?(India by law's respected)
Arhan Khan
+91-9721554271
Over and OUT
Peter N
Response - at 16.3SM per person the population is 2914. with an average floor height of 3.7M the travel is 51 Meters.
The ideal interval is 28 Seconds (wait time of 22 seconds). with a handling capacity of 13% in a five minute peak.
you will need 12 elevators to achieve excellent service. I would recommend a high and low bank of 6 cars each.
Exterior helicopter lifts.
Hire a consultant.
How to calculate the number of Lifts in a Highrise Building? Office Building as well as Residential Building. General Formula required.
there isn't one. look for examples of similar size/height buildings in the same market and copy that to start.
How to calculate the no. of elevators in an office tower of 45 floors,with area of each floor plate is 1600sqm?
handling 26 persons per min
You would normally calculate using math. Likely some combination of addition and division, but who knows?
Call your Otis/ Schindler rep and have them help.
