Roof question...help!
Jefferson
What is the difference btwn. these two roofing systems:
Single ply membrane roof, fully adhered vs. ballasted roof? They are different right?
Jun 16, 06 11:56 am
cf
Single ply- TPO? Make provision for large and fast run-off.
Built-up roof requires ballast to retard degredation.
Jun 16, 06 12:10 pm  ·
el jeffe
fully adhered = glued or screwed to hold it down.
ballasted = gravel/pavers on top to hold it down.
Jun 16, 06 12:21 pm  ·
kwarch
ballasted (membrane laid loose & stones piled on as ballast) generally preferred for large roof, with minimal penetrations, lower first cost - however structure must be sized to support. difficult to find & fix leaks.
fully adhered (entire membrane glued to substrate) preferred for more complicated roof shapes & many penetrations. easier to locate leaks. - visually - all seams show. greater installed cost
Jun 16, 06 12:38 pm  ·
Jefferson
great thank you!!
Jun 16, 06 12:41 pm  ·
waxwings
screwed is mechanically adhered
"glued" is fully adhered
see roof type family tree in this document
Jun 16, 06 2:50 pm  ·
waxwings
oh, but don't buy into the TPO adverstisement
PVC is the way to go with thermoplastic roofs
Jun 16, 06 2:52 pm  ·
noci
oh! now that site where the pdf originates seems really helpful.
can you recommend any other site like that\][;,./ oh no my kezboardlazout is fashiyyled !!
Jun 17, 06 12:44 pm  ·
waxwings
first disingenuous
and then unintelligible
did you have something to say noci?
Jun 18, 06 2:07 am  ·
noci
don't be such a mean prick, waxwings
Jun 18, 06 7:01 am  ·
8-year old posts are known for their tendency to remain dead... but not this one apparently.
Aug 28, 14 8:32 am  ·
i wonder if the OP's roof is ponding or leaking?  some questions can only be answered with about a decade of hindsight.
Aug 28, 14 9:13 am  ·
