Hi, I am designed a canopy for a tower building in Florida. Currently I am bothered by what depth I should go with. based on the structure engnieer's input, the MAX. is around 15'.
In order to cover part of the drive way, I think I need expend from the column at least 12'. But is it best to cover the drive way or I don't need to?
I guess my question is what is the top three criteria for designing a canopy.
Without knowing more about your project, it's hard to give much meaningful input. But, it would seem desirable for the canopy to cover at least part of the driveway.
What is the relationship between the entry doors and the referenced column line? Recessed, flush, or projecting?
Is there a pedestrian walkway parallel to the driveway? If so, how wide?
15' seems uninspired. Surely, a "tower building" would utilize some combination of concrete and steel for the structural system. 15' would not come close to the limits of those materials.
Or are you talking about some sort of add-on fabric awning supported by a lightweight frame?
what is the criteria of designing a canopy
Any input is highly appreciated.
