We have been doing some reading about shop drawings and it was noted that there are "Four Filters of Evaluation which are (in order of priority) 1. Fire Safety, 2. Structural Integrity (i.e. Attachment Method), 3. Safety from Contact and 4. Maintenance." - WhatsOnTheARE
Any other architects/interns/designers out there have a 5th and/or 6th criteria that they use? As much of a bore as shop drawings can be you have to admit they are pretty important regarding the quality of a construction project. We don't necessarily agree that shop drawing reviews should always be delegated to interns. (akin to composing door schedules using AutoCAD)
i know people who view it as an opportunity to sneak in some new design information thus causing the contractor to weep bitter tears of rfis, contractual letters and variation notifications.
i checked. it doesn't describe how to design changes are to be NOT made (by the Architect/ID) vide the shop drawings :o)
its an interesting conundrum (since i lack extensive contract-based knowledge): can you reject shop drawings based on new design information issued within the rejected shop drawings that should, ideally, be provided vide an Engineer's Instruction to allow the Contractor to apply for variation costs?
a. the Shop Drawings satisfy all prior conditions preceding this new set of design revisions, therefore they should be approved
b. however, if approved, you enable the Contractor to proceed with procurement/production irrespective of your priviledge as a Designer to change the deisgn (with the Client's approval) that will naturally, and understandably have financial repercussions dealt with contractually.
one rather silly idea comes to mind. you approve the shop drawing then immediately or simultaneously follow-up with issuing the design changes to invalidate and supercede the SD's content and therefore compelling (or explicitly instructing?) the Contractor to issue new shop drawings. but reviisons are built on rejected former versions of the SD.
“Shop Drawings, Product Data, Samples and similar submittals are not contract documents. The purpose of their submittal is to demonstrate for those portions of the work for which submittals are required by the contract documents the way by which the contractor proposes to conform to the information given and the design concept expressed in the contract documents.”
“By approving and submitting Shop Drawings, Product Data, Samples, and similar submittals, the Contractor represents that the Contractor has determined and verified materials, field measurements, and field construction criteria related thereto, or will do so, and has checked and coordinated the information contained within such submittals with the requirements of the Work and of the Contract Documents.”
Shop drawings are extremely important, and an important reminder that the architect's work is carried out by a number of specialists in various trades that we may know little about. I learned a lot about different elements of design and construction (steel fabrication and wood casework among others) by poring over shop drawings.
@citizen and @b3tadine It is amazing that architects need not check for accuracy and quantity in submittals BUT they often do to keep the project progressing.
They have a good laugh, then wander over to their photocopier and copy your detail on their letterhead. Most subs can't detail for shit and will take every opportunity to cut corners to save a ducet.
When architects try to supply us with shop drawings, they are typically unnecessarily complicated, poorly thought out, do not take into consideration actual material constraints, processes, and properties, lack cohesion with the larger design, are often not structurally sound/ waterproof/ able to be fabricated.
Just thought you would all like a perspective from the other side.
by the way, I'm the lead designer at a sculptural and architectural fabrication atelier. basically a detailing and structural design consultant.
A 15' double cantilever in the depth of single framing. exterior and no slope, so it either has to retain or drain water and/or snow. no downspouts. no columns. we'll support the thing on faith. let's finish it in vinyl wallcovering too.
we need to refocus our profession to those who want to design buildable buildings and get rid of those who want to be painters or sketchers or whatever.
When I worked for a contractor we would only crib the details from the architects that didn't suck, the rest we just laughed at.
Every Architect’s Dream – Reviewing Shop Drawings
0. does it fulfill the design intent of the plans
Makes sense - in the end pleasing the client is crucial.
building envelope: keep the moisture out
Constructibility
Cost
not requested. not reviewed. see ya.
shop drawings are reviewed by the architect for their consistency with the design intent. they are not part of the construction contract.
try telling that to the ID consultant we're working with *sigh*.
even funnier when they reject the shop drawing due to non compliance with design revisions made ON the same shop drawings.
for a change, one is left sympathizing with the contractor. not...
that's c141 4.5.11.
how would you go about it?
Interesting conversations going on in here. Thanks for the useful responses thus far.
http://info.aia.org/aiarchitect/thisweek05/tw0902/tw0902bp_riskmgmt.cfm
i hear those involved with preparing shop drawings stand around the submitted CD and laugh first before proceeding with their work
those that don't laugh, cry.
"i hear those involved with preparing shop drawings stand around the submitted CD and laugh first before proceeding with their work"
first laugh, then cry, then wonder is there a God, then laugh again
Best architect's details I've ever seen:
A square hole in a glass panel, in a shower enclosure, no less.
A tile floor running continuously from concrete slab to wood framing to steel framing.
A stack of 2x6 plates 12" high supporting a sloped glass storefront with aluminum frame.
This could easily turn into a very long list ...
^ The credentials of that particular architect include:
