triangular truss to truss connection detail
Oct 16 '11 5 Last Comment
rastafar
Oct 16, 11 4:07 am
Hi all,
I'm looking for the connection detail or device that would be used in such a connection between 2 or more triangular trusses coming together at a connection point. Any other buildings which contain this sort of connection or the connection itself would be a great help.
Thanks
Token AE
Oct 16, 11 9:48 am
It looks like you may actually have space frames versus trusses, but in any case:
Do research as to what type of loads are always resultant at the bearing points of trusses and you will have 85% of your answer.
LayingOutTheDots*
Oct 16, 11 11:17 am
Wouldn't you build the roof scape as one piece, rather than joining different trusses together?
Derek KaplanDerek Kaplan
Oct 16, 11 1:15 pm
missing some information -- is there a column supporting the connection points? any special techtonic expression you're after?  if yes about the column, and no about the techtonics, then since all your angles are different each one will be a custom steel connection, but fairly standard stuff
el jeffe
Oct 16, 11 2:23 pm
go to a libraray and open any book about architecture printed in the 60's or 70's.
rastafar
Nov 2, 11 5:36 am
any idea how i would go about soldering the triangular trusses with wire? are there any scale models of triangular trusses available by any hobby companies?? thx for the help!!
Please wait... loading
