Minimum Riser before needing Handrail?
clearlyambguous
I remember reading somewhere in the code that you can avoid using a Handrail if it's 6 riser and less. I can't find this reference anymore. Does anyone know where I can locate this?
May 23, 16 1:31 pm
You don't need a GUARD at less than 30". I don't know if this in any way is what you might be remembering.
I have never heard of what you're referring to. Maybe someone else has.
May 23, 16 1:47 pm  ·
The only reference I'm aware of is that you may avoid a handrail if the tread depth matches or exceeds the width of the tread. I am unaware of any other allowances base upon riser height (although a 6 inch ramp, like a curb ramp, does not require a rail either).
May 23, 16 1:49 pm  ·
senjohnblutarsky
1003.5 Exception 2.
You still have to have one rail.
May 23, 16 1:51 pm  ·
Jamb'd
For Residential:
Applicable Code: 2012 IRC Section 311.7.8
When Required: Handrails shall be provided on at least one side of each continuous run of treads or flight with four or more risers
Height: 34”–38”
May 23, 16 1:52 pm  ·
Zbig
RAMPS 6 inches or less don't need handrails. Under IBC 2015 the floor surface has to contrast with the adjacent areas.
May 23, 16 2:18 pm  ·
clearlyambguous
It's for an assembly space. I have an L shaped stair with decorative cheek walls. I'd like to be able to have 1 handrail at the corner of the L instead of at the sides of the cheek walls. Currently 5 risers at 7" with 1'6 tread depth.
May 23, 16 2:20 pm  ·
senjohnblutarsky
There are some exceptions for means of egress in assembly areas.
1028.
http://publicecodes.cyberregs.com/icod/ibc/2009/icod_ibc_2009_10_sec028.htm
http://publicecodes.cyberregs.com/icod/ibc/2012/icod_ibc_2012_10_sec028.htm
May 23, 16 3:08 pm  ·
