help with curtain wall and glass roof
alenamishkevich
Hello, I need a help with my project. In images I attached you can see part of my project and sketch with 3 problems I need help to solve. May be you ever have found similar projects, which  can give me some solutions. I'd like to see technical drawings (sketches) if it will be possible.
1 question
Roof's length is 9,5 m. So need to separate her. But in the same moment must to join glass parts with wood "beam" ("joist").
2 question
I don't know how to join 3 elements (glass roof, curtain wall and wood "beam" ("joist").
3 question
And in the end, like in 2 question I don't know how to join curtain wall and wood "beam" ("joist") and floor.
I have doubt about protect from cold and water.
Thank you for you help=)
May 20, 16 2:53 pm
I like the sketch but the model looks dumb.
May 20, 16 3:06 pm  ·
https://www.reynaers.com/architects/our-products
look at "curtain walls" and "conservatories"
May 20, 16 3:09 pm  ·
JonathanLivingston
THOSE ARE NOT QUESTIONS. THEY ARE PROBLEMS.
May 20, 16 4:05 pm  ·
1. ALUMINUM BRIDGING along splicing points
2. ALUMINUM EXTRUSION in PVB to hold your glass panels.  Your roof will be a hybrid of aluminum, structural steel section and wood
3. Raise the whole curtain wall on a discreet RC kerb
May 23, 16 4:30 pm  ·
Carrera
It will leak. Too reliant on a truckload of silicone caulk, needs to be gasketed connections between the glass & wood…in something like this the glass needs to and will move. You might be able to rout a rabbit into your wood members and set in standard aluminum stops & other shapes…stops are 2 piece and you have to be able to snap the two together after the glass is set, thus a rabbit vs a routed groove.
Not delving into the model, nothing structurally feasible about it.
Roof section would look roughly like this...could screw a removable wood cap on the top to cover the aluminum that would help keep water from getting behind the aluminum.
May 23, 16 7:20 pm  ·
SO.MUCH.CAULK.
May 24, 16 8:31 am  ·
senjohnblutarsky
Caulk fixes everything.  Or that seems to be the mantra of most contractors I deal with.
May 24, 16 9:26 am  ·
thisisnotmyname
The wood structural members look too undersized and laterally unbraced to hold up themselves, much less any glass roof system.  I would worry about that first.
May 24, 16 12:31 pm  ·
poop876
SHEAR!!!!
May 24, 16 2:46 pm  ·
