Can an elevator shaft be load bearing?
demetriadesn
I'm in high school and looking to get into architecture. I've made a few building designs, and for some, the elevator shaft would need to be load bearing; is this possible? Sorry if this is a childish question. Thanks
May 2, 16 1:57 pm
... it depends. In many cases, such as high-rise office buildings, the elevator shaft walls are designed as part of the building's shear walls. You may certainly use the enclosure of your elevator shafts (shaft is really a term best used for the actual hole, not the walls) to support structure above as long as you show them thick enough.
May 2, 16 2:05 pm  ·
That's a great question!  And the answer is yes, as Non Sequitur notes.
To the terminology question: shaft, shaft enclosure, and hoist way are all involved here, often confusingly so.
May 2, 16 2:31 pm  ·
shellarchitect
fun fact, the connections should be detailed so that the beams may fail without harming the shear walls ( fire cut)
May 2, 16 3:24 pm  ·
cadomestique
Yes, shaft walls can be load bearing.
Generally speaking (there always will be exceptions) shorter wood buildings shaft walls are load bearing while taller concrete o steel buildings are not because structural columns do that work, however if needed they can be engineered to take some load.
May 2, 16 8:07 pm  ·
shellarchitect
in tall structures elevator and stair shafts are usually used to control shear
May 2, 16 10:09 pm  ·
Yes, also as a shear wall.
May 4, 16 5:21 am  ·
