STC 35 Apartment Entry Doors
Archiholic1
Does anybody know of a STC 35 FRSC door that can be used with a granite saddle at apartment entries (in NYC)? All I have been finding are doors with specialty saddles that are not attractive nor look to be durable.
Thanks - A
Aug 3, 15 4:03 pm
JeromeS
A STC Rated door is an STC Rated door - see the link below to what Mohawk says on the matter.
http://www.mohawkdoors.com/Brochures/Doors_of_Mohawk.pdf
In order to maintain some of the integrity of the rating you'll need sound seals and a door bottom, but there is no reason this can't be done with a granite sill.  Simply specify a mortised door bottom.
As a reminder there is a difference between the published rating and a tested assembly.  Installation, sealing and all your other components will have a huge impact on the actual performance of your system, regardless of the doors individual rating.
Aug 3, 15 5:26 pm  ·
BulgarBlogger
You actually need the TL value of the door and the wall and fine the combined transmission loss through the entire assembly. I cannot imagine why you would want to specify a door with a lower STC rating than your wall... Anyway- once your get the combined TL value (this is a measure of sound pressure- a higher number indicates a more robust assembly) you can convert it to STC... There are tables that do that for you. If this calculation is for a door between dwellings, the stc value of the assembly should be a minimum of 50.
Aug 6, 15 7:46 am  ·
