Energy software to learn in a rush
Hi
I have a building and I need to make an analisis of it energy-wise and then propose some changes, preferably establishing the biggest problem with the building as it is and then fix it. It is not ideal but I am under time pressure and I just want to know if anyone can recommend me a good software to learn fast in this time of need?
Vasari for revit is easy? My revit skills are not so good now but I will perfect it during the summer but now it is too late. Perhaps I can do it in rhino and then import it? Will it be time for me to learn vasari?
Ecotect is now obsolved into revit i have heard but not sure how well.
Equest seems ok but limited choices?
EnergyPlus seems like a lot of work.
Others!?
Jul 13, 15 6:19 pm
sounds like a school project.  you should hire an architect
Jul 13, 15 7:12 pm  ·
Bench
It depends on the software you're actually building the model in. If you're using Rhino, you can run Diva natively in the software, although I found it cumbersome. More useful will be to add in some 3rd party Grasshopper applications - I found LadyBug very intuitive to use after a few hours of familiarizing myself to the program. Eve Sun sounds promising as well. Of course, these are all dependent on having a solid foundation in understanding Rhino.
On the flip side, if you are using Revit then Vasari seems to be the standard.
Jul 13, 15 9:24 pm  ·
