what is rammed concrete? material that use for Bruder Klaus Field Chapel / Peter Zumthor
Vendetta
what is rammed concrete? the material that use for Bruder Klaus Field Chapel / Peter Zumthor
Is it mean rammed earth mixing with concrete?
Thank you
Jan 18, 15 2:04 am
V - it could be something in the nomenclature, but my best guess (and it's only that) is that the chapel has a really stiff concrete mix that the owner could install, by hand, in small increments each day. so, installation wise, it could have been similar to rammed earth, but, yes, zumthor refers to it as concrete.
here's a shot of it under construction:
and, it's so thick in the sections (in places), i can't imagine there's any possibility of it being true rammed earth:
Jan 18, 15 9:06 am  ·
From A+U 2008:09 No.456, p.30:
Jan 18, 15 10:47 am  ·
mmmmm, 4 tons of molten lead.
Jan 18, 15 12:05 pm  ·
gruen
Dain blammage
Jan 18, 15 12:26 pm  ·
Janosh
It is essentially the same thing as what is called rammed earth in permitted construction in the US.  Where true rammed earth has no lime or portland cement, and uses clay exclusively as the binder, rammed concrete omits the clay and uses only sand and gravel, with 8% or more portland cement.  The materials are mixed with a small amount of water on the ground or in the bucket of a loader, and then this damp mix is put into the forms in 6" or so lifts which are then rammed with pneumatic tampers.  The final material has properties similar to 1000 psi concrete.
The projects that David Easton has built in Northern California, as well Quentin Branch's work in Arizona for Bruder/Joy et. al all use portland as the binder.  The color and character of the wall is lightened somewhat by the portland, but is mostly the result of the color of aggregate and mineral soils used.
Jan 18, 15 12:27 pm  ·
Lead is only dangerous if you injest it. Don't lick the soles of your shoes after you leave, and you'll be fine.
Jan 19, 15 6:34 am  ·
Or walk across a carpet where infants are crawling.
Jan 19, 15 9:26 am  ·
